Aloha. I'm having an issue with my fuel gauge on my '68. This is a new fuel gauge I bought from NPD. The gauge does read full when I ground the wire going from the sender to the gauge, so I know that the gauge works. However, there is no needle movement when turning the key to 'on' when the tank is almost empty. I filled up the tank after trying this, and put in 14 gallons, so there was about 2 gallons left in the tank.
I know from reading the VMF for many years that there is an adjustment on the back of the gauge that "should" let me correct this. However, on a '68 you have to disassemble the instrument panel and remove the gauge from it's holder to access the adjustment gear. I was thinking I will need to remove the fuel gauge and the constant voltage regulator and then set them up on my workbench along with a battery and potentiometer to see if / when the needle changes after an adjustment. Is there an easier / better way? (I always seem to think of the hard way to do things...).
I also have a concern about the wiring between the sender and the back of the gauge. At the sender, I had a measurement of 58.3 ohms from the sender "stud" to ground. At the connector near the instrument panel, the reading was 62.3 ohms between the fuel level sender wire and ground. So, a 4 ohm increase in resistance. Is this normal? Both ends of the wire looked physically OK. Is there another connector someplace in the wire between the sender and where the instrument panel connector is?
Mahalo, Harry Z
Mahalo, Harry Z
