I am looking to swap my small log for a big log head and have some mild work/ refresh done.
Please look at this and see if something doesn't look right.
Factory 66 inline 6 with small log. To my knowledge it is the original engine.
Head: C6D6-6090-B
Block: C6DE-6015-B
The replacement head is from a 76 Maverick (so I was told)
Head: D5DE-8090-BA
The remaining upgrades:
Schneider cam 265H (256 int/ exh, 204 int/ exh dur, 420 int/ exh lift, 112 lobe sep, 1250-4000 rpm range) - Cam, springs & lifters recommended by Jerry Cantrell
Schneider 68044 valve spring set
Schneider 5335 hyd, lifters
New valves, guides, seals (already purchased)
Factory rockers (1:6 are never available)
2BBL Sniper system. The large log head has been machined to accept it. (may or may not go this route depending on the distributor needed, sniper recommends theirs)
DUI distributor (already purchased)
Alt upgrade
Everything else is factory for the engine unless the machine shop finds an issue
Exhaust manifold/ exhaust upgrade
AC has been removed
Nothing too fancy overall.
Head: C6D6-6090-B
Block: C6DE-6015-B
Head: D5DE-8090-BA
Alt upgrade
AC has been removed
