What is the best way to set my new carb, and check the timing of my engine?
I'm sure that carbs don't come set for every engine, especially straight out of the box, so would like to hear some of your suggestions with regards to how to check that my fuel/air ratio is optimal, and how to know whether i should change my jets, and know which jets to get.
I've read that the best way to set the air/fuel ratio is to connect a vacuum gauge, connect it up and play/set the air/fuel till you get the maximum vacuum out of the engine.
Thanks guys
Thanks guys
