I've owned my project car for about 2 years and the brake lights have never worked, it's the last thing I need to fix to pass inspection. The car is a 71 Mach 1 with manual drum brakes, I already jumped the switch with a paper clip and the brake lights came on, so it's either a bad switch or maybe the wrong one? The switch has been replaced sometime before I bought the car, in the pictures, the silver one is the old one I took off, the gold one I got from O'reillys today. They're made opposite and I don't know which one is correct. The silver one was installed with the U shaped side cover to the outside, I had to loosen the master cylinder, so I could unhook the MC pushrod, in order to get the old switch out. Also there was only one white plastic washer on the pin. Shouldn't there be two? And is there a bushing that takes the slop out of the MC push rod connection? I'm guessing the side of the switch that has the U, faces down, and goes closest to the brake pedal?
