I hate to admit it, but even here in the sunny California desert it has started to get cold at night. Right now it's about 42* outside and it can get tough wrenching if it's done outdoors.
I came up with a neat solution though. I just replaced the washing machine for SWMBO because the old one crapped out but before I took it to the recycling center I removed the big tub inside. Then I took a galvanized fence pole, welded it to an old tire rim and put the tub on top so it stands about three feet off the ground. Then I loaded it up with wood and got a nice fire going.
The holes in the tub are great for letting out the heat. All I need now are three other guys and we can wrench and sing Do-*** and hang out in the cold. /forums/images/icons/laugh.gif
You all should give it a shot. Even if you don't have a busted washer, use SWMBO's. She's probably tired of doing laundry anyway and won't mind...until she finds out. /forums/images/icons/tongue.gif
