Last night I tackled the drips in the clear coat on the 70. I tried hand sanding with a block and 400 grit, wet. Went nowhere. Tried orbital sander with 600 grit, again, no progress within a reasonable time. Finally, I broke out the air long board sander and went at it with 320. After about an hour, I have the bottom 3/4 of the door runless and dripless. It looks like there is still clearcoat over the base!!!! Tonight I'll try to finish the sanding - 400-600-800-1200-1500-2000-2500 grits then buff and polish. There is one very small narrow spot on the lower leading edge of the door where I got down to the primer. I could touch it up with basecoat/ clear coat I suppose, but I am too tired of this part of the restoration to give it the attention. Also, I dont' want the delay. Maybe I'll address it later. After reading about 66BenchCoupe's pulling of the trans in the rain, I can't complain about working in a dry 48 degree garage!
