Got my '65 289 up and running after a complete engine rebuild the other day. I was setting the timing and adjusting the carb and noticed the engine temp was rising very slowly. So, I shut it off and the temp spiked and the radiator started to hiss. The hose running into the water pump literally blew off the water pump and sprayed coolant everywhere. What caused this? Just before starting the car I had added two gallons of that premixed coolant from Prestone. The local auto parts shop said the car should take about 1 and 7/8 gallons and I added two. I added two because it wasn't filling up in the radiator up to "within an inch" of the top as the shop manual says it should be. I have what I think is a reproduction of the original radiator, so it should have the same capacity, right? Anyone know what caused this? Sorry for such a long question. -Have at you, StuckInOK
