Typical open system consists of 2 open air filter breathers one on each (available) valve cover. Sometimes you may find one breather with a long draft tube running under the car. The breathers have various types of elements, some are fiberglass packed, some are paper filters and some are wet gauze types, ((avoid the ones with no internal filter or packing)). In this type of system any type of blow by or unburned fuel passed into the valve cover on the compression stroke are vented directly to the athmosphere (and creates a dirtier engine compartment if you have a tired engine).
A closed system consists of an Open air breather which is typically an element on one valve cover or a breather cap and then on the other valve cover is a PCV valve. The valve has a little ball or plate in it that when the engine pulls a lot of vaccum the valve shuts off (preventing the engine from sucking oil up into the manifold...suck on a "new clean pvc" and you'll see what I mean) and at that point the breather element stablizes internal engine pressures. In a healthy engine typically there is not a whole lot of blow by at idle, if there is you have bad rings or valve seals. As the engine moves up the rpm range and looses vaccum the shut off device in the pvc opens again and the gasses inside the engine, cause by blow by and normal wear on the oil, is permitted to travel into the clean side of the air cleaner and be re-absorbed into the combustion process. You do not want to connect the pvc to direct manifold vaccum as this will suck oil right into your combustion chambers (albeit a small amount, but it still isnt good), the air filter chamber (clean side) permits a good place for the vaccum to be equalized prior due to the air filter actually passing air where if attached to the manifold the only place to pass air is through the pvc as the throttle plates limit vaccum. Basically, make sure your pvc is attached to the air cleaner housing (some cars attach the blow by hose to the diry side on enclosed element air cleaners and others to the clean side if running either a closed or open element air cleaners. I have seen it a couple different ways.
So maintenance. You would want to replace your blow off hose every year or 12000mi along with your pvc valve (or as recommended by the parts manufacturer). These devices corrode and the pvc inner working become stuck and either over functional open(excessive oil consumption and oil burning) or non functional continuously closed (the pressure inside the engine is vented through gaskets and leaks occur). Also, use a quality oil breather cap with good packing as it filters any air coming into the valve covers and into your engine. Most cars have breatheable caps on the valve cover and others filters located in various places including the dirty side of a closed element air cleaner housing. You want to replace your valve cover breathers or line filters when they become heavy feeling or once every year or 12000 miles or as recommended by the valve cover breather manufacturer.
Finally, if you notice that your air cleaner on the clean side is getting all oily and your carb is getting dirty. There is some sort of engine problem. Worn rings, bad valve guides, bad pvc, bad tuning, blocked valve cover breather etc. You can clean the carb and other parts with a carburetor cleaner and they have routine maintence methods printed on the packaging.
Hope it helps.
