Just reinstalled the speedometer cable and guess what? It works. But it also oscillates over a 10 mph range when driven at constant speed. I guess this will be cured by a little more grease and making sure the connections are tight, but the shop manual gives a part number for the grease to use. Can I use the spray on (white lithium grease) or should I use the jelly type grease? Thanks.
