All rings (typical automotive purposes) are cast rings with various coatings. The most common are Chrome and Moly rings. Basic cast rings break in quick - great for the Mom and Pop grocery getter.
Chrome has excellant abrasive wear properties
(carbon, dust) but break in slower. It is a very hard coating. It is not a good choice when running propane (on a 390?).
Moly rings have a high melting point (4800F), therefore resisting scuffing. Scuffing is the 'welding' of the ring to the cylinder at TDC of the power stroke. Yep, it gets that hot in there! Moly rings also have a porous surface that holds a little oil and they break in fast.
There are also rings with Molybdenum Oxide, Tungsten and Titanium carbide but typically for racing only.
I would look at buying Moly rings, it's usually not a whole lot more expensive. Make sure the machinist knows the rings you're using because the cylinders require a different final honing for types of rings.
