Since the Victor Jr. don't have any vacuum ports, I'm about to drill and tap my spacer plate. The question I've got is for a 1/8" npt, what size drill bit do I need?
Just curious why you don't use a vacuum line off the carb?
I have my vacuum gauge hooked up to the bottom vacuum port on my Holley since my Vic Jr. doesn't have vacuum port either.
Yeah, this is a good point, about 1/2 the cheap gauges we have come through the speed shop have a poor taper job cut on them and cause sealing/threading problems. Don't go too deep with that tap.
I always use an 11/32" tap drill size for 1/8" NPT hydraulic fittings....best way to understand proper NPT tap depth is to run the tap down an already threaded bung or port to see how far it goes before getting tight and cutting material, then mark it (tape works good) and use that as a guide for depth. I just use my eyes (tapping thousands of holes gives me a feel for such things *G*)...
If tapping aluminum, I always use special tapping fluid for non-ferrous metals or kerosene...
Just remember, if using kerosene as a tapping fluid, to just drizzle it onto the tap as you're cutting and to make sure the area is well-ventilated and away from standing pilot lights...
Most folks use the non-flammable, non-toxic, politically correct tapping fluids but I'm somewhat of a rebel..*G*
