[Solved]Holley 4160 Secondary throttle adjustment screw thread size
6.5K views 20 replies 6 participants last post by  GeoffTheGiraffe
#1 · (Edited)
EDIT: Its a 10-32 thread
Does anyone happen to know the thread size for the small adjustment screw located on the underside of the carb base plate? The original screw seized in the hole and the extraction ruined the screw. A replacement is $10 and a few days wait. I am very inpatient and Id rather possibly find a screw with the matching thread size and pitch that I could modify to fit.
Worst case I order the screw and be done with it.
Anyone know what thread size and pitch? Thanks!
It’s almost impossible to adjust these little screws without taking of the carb, which is pretty hopeless if you want to fine tune it. Maybe you can find a longer one so that you can access it with the carb in place. But maybe it would interfere with something, not sure.
Take a bolt or screw with the same thread, pitch, cut it to links, put it in advice and use a dye grinder to cut a slot in it, smooth it out and see if that works
It can be done, especially if you replace with an Allen head.
This is on an old holley 750 I got for a steal. On my holley I actually inverted the set screw so the flat head is facing upwards. I then ground down a small Allen wrench to have a flat head and I use that to adjust my secondaries without having to remove the carb
Which has me thinking I could possibly make a custom bracket using pieces from a mechanical secondary shaft bracket that will allow secondary adjustment with a thumb screw while the car is running.
If you're still wondering, the secondary throttle adjustment screw thread size is 10-32. I used a 3/4" long hex bolt because for me, it's easier than the Allen set screw I had before. The slotted set screw that comes with the carb is flared slightly (hence the deep slot) to keep it from vibrating loose. Use a removable threadlocker or you'll lose the bolt.
  • Helpful
Reactions: GeoffTheGiraffe
Great! I had actually ordered some allen head 10-32 screws on amazon based off an ancient forum post somewhere. Glad to know they where right! Should confirm on monday when they arrive.
As for keeping my screw secure, 19 year old me decided that mucking up the threads with rtv to keep it from coming loose was the best course of action :ROFLMAO: Its held for a few years and several adjustments so fingers crossed lol. The other carb receiving the fix will get a little dab of some loctite to be safe
#20 ·
I just turned 24 this summer haha. I like to read a lot! And I love learning new things every day. I have the forum open on one of my 3 monitors and scroll through whenever I take a break from staring at and writing endless lines of C++ and C# :ROFLMAO:
