Edit: I updated the status of this problem in post #24
My car has an after market Tach, installed by the previous owner, so I have no idea if it works properly or is wired properly.
Problem = The needle on the tach jumps up about 500 RPM about every second or two, but the engine sounds normal, no idle issues.
What I know = The tach has 4 wires (Black, Green, White, and Red). The Black runs to ground. The green goes out to the negative terminal on the coil. The White and Red wires are put together and go to a switched power source. I'm assuming one of those last two wires is the power wire and the other would normally go to the light switch so the tach would light up when the car lights are turned on. In this case, the Tach lights up when the car is on.
When the car is idling, the needle mostly sits at what would be the idling RPM, but then it'll bounce up a few hundred RPM and fall back down. The sound of the car does not change, so one can tell the actual RPM is not bouncing like that.
What can cause this needle bouncing? A bad ground? A bad power source? A bad coil? A bad Tach?
