TKO 600
2.3K views 12 replies 9 participants last post by  Maxum96
I have a 1969 Mustang with a 410 stroker an a tko 600, anybody got an tricks to help this transmission shift better or am i just stuck with it, oh yeah its all stock shifter an trans.
#2 · (Edited)
I have a TKO600 from MDL w/carbon fiber syncros and their shifter in my 69. TKOs, in general, are just notchy when shifting especially at high RPM, they are not Toploaders where you can just bang gears and shift quickly.
after 2 years with their transmission, they are still notchy when shifting at high RPM but when driving casually, shifts are clean and smooth. Might just save up for the TKX as the new revised version from tremec fixes this issue.
also, I would recommend getting a short shifter from Hurst or MDL's Quick Shifter to help with the shifts.
#4 · (Edited)
I couldn't shift into the next gear above 5K rpms with my TKO. It was very notchy / hard shifting. I sent my TKO to Liberties Gear, they added carbon fiber blocking rings, added bronze fork pads, changed the shift finger, modified the top cover, 5th shift rail and selector rail rear extension. $567 plus freight. All problems were solved. shifts like a dream up to 6200+.
Fluid in the 5/600 makes a huge difference. I had Royal purple in mine when I first got my car on the road. Shifted terribly, wouldn't go in to gear when driven in anger, was incredibly disappointed. Thought it might even be my clutch adjustment or something, but no bleeding or adjusting made any difference.
I swapped it out for pretty annoyingly expensive GM syncromesh (got mine from my local Chevy dealership, parked my fastback right in front, LOL) and after a bit of driving, it shifted like a T5. I've had it like that for a few years now, and I thrash the crap out of it in the canyons, never skips a beat.
As far as I can recall, Tremec has always spec'd GM Synchromesh for their transmissions. My 3550 is old and shifts like a dream.Yes, it is notchy, but not in a detrimental way. The other thing important thing to consider is a 2000k break in period. Just drive the car around and shift through traffic to let it loosen up and knock the shine off of everything. It is pretty common that beating on these right out of the box can lead to clunky shifting for the duration.
