Turn signal plus in dash harness
8K views 7 replies 5 participants last post by  PhantomSi
I'm putting the car back together. My fault I didn't label anything. I just want to confirm that this is the turn signal plug in the dash harness. There's another one on the right side of the column above the ignition switch.
Thanks in advance!
Sam
If it's an early 66 (or 65) with an emergency flasher that is hard-wired into the wires then the emergency wires will plug into the turn signal plug and then the wiring harness plug (what you took a picture of) will plug into that. Kind of a jumper. If you have an emergency flasher that unplugs from the wires then that's not the case; the harness plugs directly into the turn signal wires coming out of the steering column.
The Wiring Diagram book is really helpful for these connections and it's only a few dollars.
#6 · (Edited)
Ok that helps. The white connector I believe you are referring to appears to be the connection to the sub harness on the back of the instrument cluster. The turn signal connector is similar 10 pin connector. You’ll have to look at the connectors or the wire colors to confirm which is which.
