I need a little help please with my turn signal cancellation issue. I recently installed a new steering wheel on my 1969. The new steering while is a Volante 9 bolt steering wheel (steering wheel and adaptor). After the installation, the turn signals would still cancel although not as good as before the new steering wheel. After two days, they will not cancel at all unless I manually cancel both turn signals (right and left). I have removed the new steering wheel to check the turn signal cancel cam. It is intact and appears to function. I think I have the steering lined up properly but the signal won't cancel. I am not sure what I else I need to do. Any suggestions would be greatly appreciated. Thank you in advance.
Here are some helpful hints might be appreciated for anyone having difficulties in getting their turn signals to work correctly. I'm enumerating for clarity and assume if you are reading this, you are having turn signal trouble. Please note that these comments are reflective of my experience with an aftermarket nine bolt steering wheel with the turn signal switch in good shape. Corrections and additions from Forum members are appreciated and encouraged.
1. Make sure your road wheels are exactly straight before you remove the steering wheel. I used masking tape on the steering column and steering wheel hub and marked the position of the wheel with a magic marker so I wouldn't lose the setting in case the front wheels moved during steering wheel removal and replacement.
2. When you pull your aftermarket steering wheel you should see two roll pins protruding from the back of it. If there are none, or only one, the wheel will not actuate the turn signals correctly.
3. You can obtain roll pins that work at most hardware stores. I found mine at Summit Racing.
4. Be careful about driving the roll pins in too far. They have to protrude a short distance out from the back of the steering wheel or they won't actuate the turn signal switch. I know because I had to pull the wheel twice before I discovered that little nuance.
5. When installing the steering wheel, the two roll pins must face left with the distance between them divided by the turn signal lever. I used a piece of masking tape on the wheel hub and marked the the location of the roll pins on the tape with a magic marker so I could correctly position the wheel.
6. After following the above steps, my turn signals worked perfectly but the steering wheel was out of line. Mine is a nine bolt type so I removed all nine fasteners and reoriented the steering wheel accordingly. If yours is still off, you may need a trip to the alignment shop because using the splines on the steering shaft may throw the turn signals off, creating the same problem you are trying to solve.
