Ugh! Creaking from front suspension. (Video.) Anyone heard this same noise?
3.7K views 31 replies 12 participants last post by  scottmil
Ignore the horrible (read: no) lighting in the video. That' the LCA and the tie rod.. I just needed the audio. Towards the end of the video, the sound gets more clear as it slows.
I can 'feel' the creek in the LCA but no where else. Although, I suppose that does not necessarily mean it's coming from the LCA.
Perches are roller (Don't feel to be grinding).
Strut rods have rod ends at the front (Don't feel to be grinding).
Upper shafts are greased.
Has anyone heard this noise before? Sounds like it should be easy to pinpoint, but, not having much luck on my own!
https://youtu.be/63woab2x9NI
Thanks guys!
#3 · (Edited)
Shouldn't be the pad, less than 1000miles on it or so.
UCA have 2500miles on them and I pumped them full of grease a few months ago. I can see the grease coming out the other side when I look from underneath.
I suppose I Must disconnect the spindle from the LCA and try moving the LCA independently. I'm just afraid I won't be able to feel/hear anything that way since it won't be loaded as it is now.
Normally I'd agree with the UCA but I can only feel in the lower, but as I said, that may not mean anything.
I...... Do not recall! Definitely not urethane... MAY have been this 'fake' material called Midolyne that doesn't actually exist in real life, so I can't be sure what it is.. I can't even recall if that is what i bought or not!
As for the spring pad, do you mean at the top? Also cannot recall, but we can assume worst case urethane.
But it sure feels and sounds as if it has to do with an up/down movement, not a 'rubbing' sensation.
Ugh, I hate disassembly.. 1 hour drive time to 10 hours maintenance. hah
(The reason I'm hesitant to say it's something simple like a sway bar to frame bushing, is because you can also feel each creak while pushing down on the fender.. Each creak has a tiny bit of resistance, if you dig what I mean).
You need a helper to move the car up and down while you man the stethoscope to determine the exact location.
#28 ·
JohnnyK,
Can you please post some good pics or a better video of what you are using for your strut rod/attachment. Did you purchase your rods/heims as part of a kit or did you piece it together yourself or ?
Shaun,
What would cause this failure. Do the heim joints you mentioned have some type of defect or ?
Im looking at having this type of adjustable/non rubber bushing setup on my 68 and would like to understand whats going on here.
Thanks all,
Paul
#30 ·
Thank you!
Paul
