Upper Control Arm Thread Protrusion with Reinforcement Plates
2.3K views 21 replies 10 participants last post by  key_24
There's always Nord-locks. about $ 5 to $7 at mcmaster.com for a 1/2". posted this link because the photo is bigger.
Maybe Shaun at SOT or open tracker may have knowledge of where to locate longer bolts that are correctly knurled....
Shaun uses grade 8 bolts/nuts in this application. The only down side is you gave to hold on to the bolt head to tighten them up.
I don't think the commercially available version of that reinforcement is quite as long as yours. Also if you were to relocate the UCA, you would have a problem with that reinforcement in place.
