On my 66 I have replaced the outer cowl panel and do not have the studs to hold the windsheild molding clips on. My options are to use the 65 style clips with screws or use the 66 clips with screws. After studying the two clips I like how the 66's clip onto the molding, they seems to grip better. I was not sure if I would run into any problems using the 66 clips with screws, I did compaire the two clips and see that once I drill the holes they will line up differently depending on which ones I use. Can someone offer any suggestions that has been in my predicament before? Thanks Brian.
