The stock 390 4 bbl has the pcv on the passenger rear valve cover and feeds to a connection on the back of the carb spacer. I see alot of so called correct 390 pictures on [censored] etc that have a hose coming form the drivers front valve cover and connecting to the front of the air cleaner. I question the need for both valve covers to have a hose connected to them. Also did the 69 390 have a heat riser on the passenger exhaust manifold that fed hot air up a large tube to the bottom of the snorkle? Appreciate the answers to the above.
