Will a 2.83:1 Standard Differential on 1967 Mustang work with a v8 engine?, those are the specs on the rear axle on my 67 Mustang and I was wondering if I could swap out my inline 6 for a 289 , preferably 302 without having to change rear ends
As far as what you’d feel they’re the same. It’s the ratio of the teeth counts between the ring and pinion so for every 2.83 teeth on the ring gear, there’s 1 pinion tooth. Ring teeth divided by pinion teeth = 2.83 in your case. Mine is a 9” rear gear so the ratio was just slightly different than yours (2.83:1 vs 2:79:1) but they’re basically the same.What is the difference between a 2:79 and a 2:83 rear ?
