Upgrading to 100a 1 wire alternator from Jegs. Replacing an Autolite 3 wire (no external regulator).
The battery post on alternator is hitting 289 block (see pic). I can't tighten down alternator and get the adjustment bolt in the adjustment bracket that bolts to the water pump.
Can I remove the bolts holding the two halves of the alternator and rotate the lower half so that it isn't directly under the main bolt?
Is there a better way to do this? :loco:
