1967 mustang coupe emergency brake return spring question
4.4K views 15 replies 8 participants last post by  TexasEd
I am restoring my daughters coupe and noticed I have to push the emergency handle back in when releasing the brake ordered and received a mustang e brake spring but can't figure out how to attache it. The shop manual says there isn't one but I noticed the falcon for that year has a spring attached to the brake cable up front. is there an after market fix for this spring omission?
I believe you are referring to the spring that attaches to the parking brake lever located next to the transmission. Here's a couple of (before restoration) photos showing that spring. In my car there was a small hole in the floor pan, but I don't know if that was factory. Another issue may be the cables going into the rear backing plates. They have return springs built into them, however those cables are very suceptible to rust and not returning smoothly. Sometime they can be lubricated, but also may need to be replaced.
I don't think that's factory but that's what I was going to do thanks for the reply i'll make a small bracket and rivet it to the floor not that we use the brake much but a least the cable won't come off the pulley at the brake handle assembly. The CJ picture isn't exactly what I have the spring pulls at an angle on my car and wouldn't work.
The shop manual is correct, there isn't one.
Depends. It can be correctly stated that there is no individual parking brake spring located at the front of the car or near the transmission like previous years. However, it should be quite obvious that there is some type of spring action needed to return the parking brake to normal after engaged. So yes, there is a spring - in fact there are two springs. They are not individual part numbers, they are included as part of the parking brake cable assemblies, and are located just outside of each rear drum.
