Looking for some help picking out the right pistons and rods for my 351w build. This is my first engine build so I'm a bit new at trying to figure out the internals.
What I have is a 1984 351w block that was originally out of a truck. I have the following parts for it so far...
Aluminum Heads (J&C ebay store) -- similar to these only in 190cc 289 302 347 351W Small Block Ford Aluminum Cylinder Heads SBF 2 02 Intake 185cc | eBay
Eddlebrock Performer RPM CAM
Aluminium Roller Rockers (J&C ebay store) --- same specs as these only in aluminum 1 6 Small Block Ford 302 351W Stainless Roller Rockers 3 8 SBF | eBay
Eddlebrock Performer RPM Intake
Eddlebrock Performer Series 750cm Carb (Part #1407)
I'm under the impression that I have lower compression currently due to being a truck engine. What would be a reasonable compression to run for a street application? Hoping for somewhere in the 400HP range. Will never drag race with it. Just want a nice sunday cruiser that still has some kick to it.
As of right now I'm a stock bore. Ideally I'd like to stay there unless there's a big reason to go larger.
What type/size pistons and rods would you guys recommend for my application? Can I run them using the stock crank from the trunk motor? Trying to keep the budget down where possible.
Thanks for the help!
