So I know this is going to be a bit controversial, but...
I know where I can get a six-cylinder '68 coupe with a broken camshaft for $650. Right now I'm not interested in owning another gas-guzzler, and yes, the six still counts as a gas-guzzler. What if I put in a 4 cylinder 22R-E engine and transmission from an older Toyota truck? I estimate the whole thing would come out to about 2600 lbs, so the engine should be able to handle the load.
I'm not talking about some "fast and furious" conversion here with underglow and 22 inch "rimz". I'm just imagining a nice, stock-looking '68 Mustang without the usual gas money penalty.
I'm thinking this conversion could be carried out with few or no permanent changes to the structure of the car so a traditional drivetrain could easily be put back in. I know I'd need to fabricate engine and transmission mounts which could probably be mounted at the stock mounting points, as well as a driveshaft. Also a wiring harness, EFI plumbing, shift linkage, throttle linkage, etc.
What do you guys think? Has anyone heard of someone doing a swap like this? I've only ever heard of people putting larger engines in their Mustangs, never smaller.
