After driving my '14 with a 302 for a few weeks, I've decided my '65 would definitely be funner with a 302 as well. Spurring this on is the worn out clutch on the current I6 (totally my fault- when I converted to a T-5 trans, the clutch was adjusted too far out and I think I warped up the clutch pretty good before adjusting it properly).
Here's where I am today-
A couple of questions:
Should my T-5 hook up to an '85-92 engine without difficulty?
Will a fuel injected 302 be trickier to install vs. a carb engine?
What else will I need (e.g., can I use the radiator from the '85-92)?
Anything obvious I'm missing (e.g., I have had both ends of the driveshaft converted to the proper joints for the T-5 and 8" rear- am I okay with the original driveshaft)?
I've drooled over the I6 build thread by GoPen, but I think it will be cheaper and easier to just plop an 8cyl in there like everyone else. Assuming I can find the right car, I'm hoping to get through this on a budget of $4,500 or so.
Thanks for any input to a topic I know has been discussed often.
- 8" rear end installed
- Front steering/suspension from Chockostang installed
- '65 V8 discs/dual MC from Chockostang installed
- V8 springs installed
- T-5 installed
- Sanden A/C compressor
- No power anything
