67-68 Mustang Tach
5K views 9 replies 6 participants last post by  sixtysevenGTconv
The factory tach in my 68 GT has a burnt transformer according to the mechanic. To ship to the US [from Canada] to Bobs Speedometer to rebuild will be expensive. I have come across a guy with a vintage 67-68 Cougar Tach that I can get for $75. Does anyone know if the 67-68 Mustang & Cougar Tach's are interchangeable? I have attached a pic of the back of my Tach.
#2 · (Edited)
It all depends. The basic tack is different. The XR7 tachs internals are the same as the Mustang but the cases are not identical, but you can make it work with a little creativity. The warning lights are different too.
You can get it rebuilt/repaired by Tachman, or get it converted to a modern Tach by Rocketman
Tachometer Repair Restoration for Antique Classic Cars Auto
Rocketman Tach
#6 · (Edited)
In a vintage Ford power comes from the ignition switch and goes to the coil through a resistance wire. (The wire lowers the voltage). When installing a vintage tach, it goes between the ignition switch and resistance wire. Every time the coil fires it creates a pulse in the wire. The tach translate these pulse into an engine RPM. This is very accurate way to measure it. The downside is that if the tach fails it can prevent the flow of power to the coil and the engine won’t run.
Modern three wire tachs tap the ignition power prior to the resister wire and have their own ground. They also use a signal wire to provide pulses. In this way they are isolated from the ignition system’s pr8mary wiring. This syste is a little less accurate, but more reliable as failure won’t prevent the ignition system from working. Depending on your ignition system the signal wire can come from different places. See the following diagram from Rocketman’s website on proper connection options.
#5 · (Edited)
And if you go with the modern three wire setup, the engine will still run if the tach ever goes south again, because it will not be wired inline as a series circuit like the factory original two wire tach was. And last time I checked, even Tachman repairs them as three wire setups as the old D'Arsenault (forgive my lame spelling..) factory style movements are pretty much all gone/used up by now.
Can you show us the face of the Cougar tach so we can identify it. If it is in good shape a qualified repair shop like Tachman can use the internals to fix your original Tach. Otherwise you are looking at converting it to three wire.
