Since nobody else is jumping in here with crazy wiring suggestions I'll start.
Looking at the wiring diagrams I think the red wire formerly used for the Amp gauge should be a good 12v+ source. Double check it, but that should probably work for your Red VE+ line.
The best ground for the Black VE- is probably the bolt that holds the voltage regulator on. It's right next to the speedo cable.
The Yellow Pulse wire is going to have to go to the ignition coil on the engine. Since you didn't have a tach before there's not going to be a wire for that, you're going to run that one yourself.
If you want the low oil pressure light to work you're going to have to get a light bulb obviously but you'll also need to change the sending unit on the engine to the 'warning light' model. It's basically an on-off switch. If you did that I think you could probably just hook the original oil pressure gauge wires up to your light bulb and it'd probably just work.
I have no idea how you'd make the ALT warning light work. Hopefully somebody will jump in here to say everything I've typed is wrong and they'll know how to fix that light too.
Hi thanks for your reply
I am still stuck on the first step before i hook up the tacho, i have installed a clock in the middle an that works so does my gas gauge
I have dash lights that work an dim but when i put my hi beam lights on i do not have a light working.. have checked all bulbs are good
i have removed the red and yellow wire that was for my ammeter an taped them off
Also taped off the white with red strip and a black wire which was my oil pressure gauge
Now when i turn my intercators on left or right they blink really fast on the dash and also at the front an rear
But when i put the hazard lights on they blink at normal speed on dash and on front an rear
Any idea whats going on?
I have read somewhere on this fourm to make a alt light work that i need to switch S to I on my regulator and also run a new wire from S to the S post on the alternator..
I am yet to do that change along with the other steps for the alternator light
I have brought the correct fitting for the motor for my oil light
Before i plug in the tacho or go any further with alt oil light i would like to get the above issue sorted before i move onto the next challange
