Keeping with the Theme today...
I'm having a major problem installing the gas tank filler neck on my 72 mach 1
New repoduction tank(never filled with fuel)
New Tank filler neck seal.
old filler neck.
first i had the tank installed with the straps in place. and i noticed the filler neck was at a VERY steep angle and i couldn't line it up with the rubber seal to push it in.
So i tried lowering the back of the tank, to make the alignment of the bottem of the neck and tank dead on. I pushed for 2 hours, i tired bolting the neck to the car and jacking the tank into it, but the neck refused to mate with the seal. Finally i dropped the tank out of the car, and tried to just push the neck into the tank outside the car to see if it was possible, and sure enough the neck "refused" to go into the seal no matter what i did.
Now i have the tank sitting on the floor, the neck sitting on the floor and me sitting on the floor crying for help.
is there a trick to this? i tried some grease nothing worked. I was thinking that since nothing has had any fuel in it, including my new gas lines, to maybe use my heat gun on the neck seal donut heat that puppy up and then try jammming the filler neck into it in the hope the heat would of softened it up.
Please help anybody have any ideas? its really maddening, since it took me forever to get the tank under the trunk floor and i have the bruises and cuts to prove it.
old filler neck.
