65 Coupe. Looking for any been there/done that advice on trim clips. I haven't seen any discussion on clips/screws that are missing/gone.
Body shop repaired some rot at the rear window channel area, and now most of the screw holes are filled. To add insult to injury, they put the trim back in with urethane sealant, so now I have to figure out how to get that stuff off trim and window channel.
Is there a method to locate screws for the clips? I know that laterally it makes little difference, but I want to ensure that a) the trim will clamp in and b) the trim will run true.
I was thinking of measuring the position of one of the remaining screw holes, and then running masking tape to make a guide. Then drill new holes. Any experience?
K
K
