Any crap sticking to your wall after all this flung at it?
Ill help spend your wise money also.
Know that A code made more power over your C by way of pistons that raised comp ratio.
Cobra HO GT40P iron heads, supposedly the best flowing stock heads Ford has come up with. Found Cheap $2-300 or less if theyre not wise from JYard Explorers 97-01 with 5.0. Check how much you should mill to bring chambers from 57 to under stock 54cc or less. Not much porting needed just some bumps removed. Lots of info on these. No need for whacko springs and such with the right cam on a street car. Wanna spend more $$ GT40X or Y? Same things in aluminum.
Look at Comp cams 31-230-3 or 31-234-3
SB Ford 289 - 302ci Xtreme Hydraulic Camshaft # 31-230-3 | Northern Auto Parts
Using an online hp/torque computer these grinds are awsome for off the shelf stuff for our needs. Other brands with similar specs are plentyful.
Some headers and with less than 1k youre shredding tires with the best all in a weekend.
225ftlb to 370ftlb+ 1200-4000rpm with a nice curve
330hp @ 5000
Try this combo and report back. I would but my 5 speed fell through and I need that 1st.
HP is for show Torque is what makes you go!
