There are several visual clues to look for and you don't have to take anything apart. Look at the gaskets for the water pump/timing cover and between the cylinder head and block. In many places they extend out and away from the sealing points. If the gaskets appear new, then you know someone has at least been in there for some reason. To look inside the engine, get an inspection camera or Borescope. You can get a decent one for just under $150. I've seen them at Harbor Freight for $89. Pull a plug and look down in the cylinder. Look for good crosshatch on cylinder walls. Also, look at the top of the piston, like Varilux said, you may see a number stamped on top such as .30 or .40 - if there isn't too much carbon build up. If you see these numbers, then the engine has definitely been rebuilt at some point. Next you can remove a valve cover, loosen a rocker arm and remove a push rod. First be sure the camera is small enough to fit thru the push-rod hole to view the lifter valley. To look at the bottom end, you will obviously need to drain the oil, then feed the camera up through the drain plug hole.
