Redoing the colors in my engine bay, everything has been out. Now, when all is back in, I got brake problems. Pedal feels ok until I fire the engine. Then the pedal gets very loose and hits the floor and the rear brakes locks very easy. I'm tempted to install a new Booster/Master Cylinder, but is there anything I should check before spending the $$?
Also my Tilt Steering Wheel has change. Now it only tilts, with the engine running. Before I could stop the engine - open the door - and it tilted away. It seems it doesn't build up vacuum in the tank.
Just a thought - when both brakes and Tilt uses vacuum, could there be a connection?
Is it possible to reinstall any of the hoses wrong with this result?
The car is a -67 w/ disc brakes.
Thanks in advance.
Paul
Thanks in advance.
Paul
