brakes
648 views 8 replies 5 participants last post by  johnpro
Hi, I have a 65 mustang coupe 289, with factory discs in the front. Lalely ive been having some problems with my brakes, they travel. My mechanic told me that my master cylinder is shot and it needs to be replaced. i told him about a few articles ive read about people swiching up their single for a dual cylinder. he said that it would be complicated. So im just trying to get an idea on what exactly is involved and how much it would cost so i can budget.
Also i bought the shelby side exhaust and all i need is headers and hangers, any suggestions on hangers or headers would be much appreciated. i am leaning twards the tri-y's, but if there is a specific company thats good. thankss
You need the '67 distribution block or fabricate a way to split the brake lines, since the '65/'66 distribution block doesn't have a provision for hooking up the other cylinder. The '66 lines won't hook up to a '67 MC, so it's best to get the '67 MC to distribution block lines, then adapt the ' 67 distribution block to the brake lines in the car.
If the car has power brakes, you can't use the '67 MC ... it won't clear the shock tower with the stock power booster.
Correct. The Power and MAster pedals have the pushrod connect in different places, IIRC. Since all he is doing is changing one MC for another, no pedal mod is needed.
As for the proportioning valve, the factory disk MC had two lines coming out, one to the front distribution block, one to the rear. The fittings are different sizes between MC's, though.
Use the push rod from the original MC.
No. You need the combination valve from a 67 later drum brake car otherwise you've accomplished nothing for safety. That combo valve blocks off the failed side (in a brake failure situation) so that the good side stays intack. Basically its a shuttle valve. It usually has a brake warning light switch too, which can be hooked up to a dash light.
I think all you have to do is use a 67 master cylinder and match your lines to it.
