Hi all,
I have a problem of trying to get my electric fan to shut off. I'm running a 331 with a nice aluminum radiator with a Spal 16" fan. Kicks on when its supposed to but rarely turns off. My temp gauge is reading normal and per my laser temp gun, all parts of the cooling system are fairly normal,like 185-195, except where the sending unit is located.
As you can see, I'm running heater pipes instead of hoses; they're off some Ford car but don't know what. I liked its configuration better than the late model Mustang type.
Anyway, the area of the pipe where the sending unit sits is a good 15 degrees hotter than anywhere else, hence, it doesn't cool down enough to turn off the fan. The sending unit is for 200 degrees on, 185 off.
So, is there a sending unit that exists (Spal maybe) that I can use for both my stock guage ('66) and my fan trigger so I can install it in the stock location in the manifold? Or, is there a better place to put this sending unit, while keeping my stock one, for a more accurate temp reading?
Unfortunately, I have only the one hole in the manifold water area for a sending unit. I was thinking of drilling another? Bad idea maybe?
What do you think?
What do you think?
