Hey guys! I'm a auto newbie having electrical problems. The 7.5A fuse keeps blowing for the interior lights on my 66 mustang fastback. If I remember correctly it occurred after installing the interior LED kit form scott drake. I had some LED and some incandescents installed when I plugged the battery to check how they looked. The door switch was broken so i thought it came from there. I replaced the fuse and the only light on was the glove box light. The lights stay on for about 1 minute and then it will blow. I also installed Dakota digital gauges, but it blew before I wired anything if I remember correctly. But just in case, here is the wiring for the gauges: 12V constant spliced from cig lighter(Blue/white), switched power from radio(black wire that goes to accessory fuse), power for light dimmer spliced from tail light harness (black wire), main ground wire run to passenger side kick panel factory ground hole.
None of these are in the dome light circuit if I am reading the wiring diagram correctly, and the gauges work jus fine. Could it be the mix of incandescents and LEDs? Bad light switch? Wouldn't a short to ground pop the fuse immediately vs staying illuminated for a while and then blowing? Maybe the harness is plugged incorrectly? The courtesy lights used to work correctly until now.
ANY help is appreciated.
