I recently had a set of SPC upper control arms installed on my 65 convertible, along with adjustable strut rods and an alignment. The specs are around 1-1.25 degree negative camber, 4 degrees positive caster a slight bit of toe in equal on each side. The problem is, they installed them in the Shelby drop holes and these UCA's have the drop built in, so I'm at a 2 inch drop. I am going to move them back up to the stock holes and was wondering if anyone could tell me what just moving the arms does to the alignment. I will be getting an alignment done, but the shop is over a month out. Thanks! Chip. (I finally got finished with the paint! Turned out pretty good for my first I think.)
