Ok...this is what i have so far as my parts list for my efi conversion:
Engine assembly
Transmission
Intake manifold assembly…
Injectors
Fuel rail
Fuel rail adapters, metal tubes that go down by oil pan
Throttle body
TP sensor
Air bypass valve
ECT sensor
ACT sensor
EGR spacer
EGR valve & sensor
Heater hose tube
Air intake hose
Mass air flow sensor
Barometric pressure sensor
Oxygen sensors
EGR valve solenoid
Computer (PCM)
Accelerator pedal
Accelerator cable
Inertia switch & connector
TFI distributor
Ignition coil
Fuel filter bracket
Starter solenoid
Valve covers
can anyone add anything else? Also...what valve covers will work and have enuff clearence for the upper intake manifold? and why on earth are there no direct guides lol
Engine assembly
Transmission
Injectors
Fuel rail
Throttle body
TP sensor
Air bypass valve
ECT sensor
ACT sensor
EGR spacer
EGR valve & sensor
Heater hose tube
Air intake hose
Oxygen sensors
EGR valve solenoid
Computer (PCM)
Accelerator pedal
Accelerator cable
TFI distributor
Ignition coil
Fuel filter bracket
Starter solenoid
Valve covers
