I'm trying fix fix some of the hacks that the previous owner did ,The drivers side engine cross member bolt has been broken since I've had the car 15ish:shrug: years the cross member was moved slightly forward and held in with a 3/8 self tapping screw .I got the broken bolt drilled out albeit slightly off center tried using a screw extractor with no luck .So the way I see it I have 2 chances first is getting a drill and tap combo http://www.homedepot.com/p/DEWALT-27-64-in-Drill-and-1-2-in-x-13-NC-Tap-Set-DWA1416/204787201 and if that doesn't work finding the elusive 17/32 drill and trying a heli coil
Will somebody confirm the bolt as 1/2 x 13
AMK F1280 Mustang Engine Crossmember Bolts (2)
