With help from this site and Huskinhano, I put together a 1999 GT40P with Ford E303 cam and TFS spring kit. The engine runs very well. My issue is that my temperature is erratic. It will slowly go to 180, then shoot up almost immediately to 230 then down to 160 and repeat, ad nauseum. It’s only about 40-55 degrees out where I live currently. I’ve tested with two mechanical temp gauges and both respond the same way. I think something is going on with hot spots from air bubbles or a clogged radiator?
The champion 4 core radiator is about two years old and I ran it with my old 289. The 289 had tons of crap in the cooling system and I flushed it several times before installing this 4 core radiator, but, it still had some junk in it. I’m wondering if my problem may be a clogged radiator. I have called around restoration shops locally and no one knows where I can get a radiator cleaned anymore, as these places have all closed. I’d hate to have to replace my radiator again since it’s pretty new.
Everything but the radiator in the cooling system is new: stock style water pump, new radiator hoses, new 13lb cap with lever release, new heater core. I have tried three different thermostats, a high flow racing 180 (wouldn’t get up to operating temp), a stock 195 (gauge bounced around) and a 180 (gauge still bounces) which I am currently still running. I drilled one small hole in the stat to try and help burp the system before install.
The engine runs points ignition, 14 degrees initial timing.
Here’s what I’ve checked so far:
- Pressure tested the cooling system to 17 psi and found no leaks
- Ran car up to temp with radiator cap off to try and bleed system
- I’ve now installed an inline heater core filter, and a radiator aeroflow filter to help clean the system
- Repeatedly pulled radiator cap release lever once system is pressurized in an attempt to bleed air out
- Run a snake camera down each cylinder to check for cylinder wash from antifreeze
- Cold cylinder compression tests are all 160-165 psi
- Cold cylinder leakdown tests are all in the 1-3% loss range
- No cross contamination that I can see of oil/antifreeze
