1 - 9 of 9 Posts
alaroque
· Registered
Discussion starter · #1 ·
I am a stupid stupid man!!!!!!!!!!!
Enough said?
No, I am embarrased to say this, but after spending about $500 to try and cool the engine with aluminum radiator, new perma-cool fan, perma-cool 14" electric pusher fan, converted to high volume water pump, new custom hoses because the alluminum radiator is actually made for a chevy (remmember the 69 351W has a passenger side water pump, which is the same as a chevy, and the aluminum radiators are a dime a dozen with the chevy configuration, so I decided to relocate my upper hose rather than get a water pump which takes water from the drivers side), I have solved my problem.
I had the thermistat in backwards, with the sping pointing towards the radiator, not the motor. The water would heat up in the block building pressure, then it would open allowing the cooler water to enter the block and the hot water to go to the radiator, but as soon as the pressure built up in the radiator, it closes the thermistat for good. Here is how I realized what I had done. I was looking through the April 2001 Mustang and Fords (I had it on my desk at work since April) for an advertisement for the D.U.I. (davis unified ignition) distributor with built in coil because that was going to be one of the next things I replaced to solve the overheating problem. In that issue, there is an article titled Understanding Cooling Systems. I started to read it and there is a diagram of the water thermistat in the housing, and the spring is pointed towards the motor. I thought, I wonder if mine is positioned correctly, so I ran home for lunch, took the hose off and sure enough, I was staring at the spring. Its in backwards. No wonder the damn thing has been overheating.
Boy, what a simple mistake I made during the motor buildup.
So, remmember to pay attention to the small details, this one sure cost me time and money, and it was a stupid mistake.
Ok. You know, we won't call you stupid. Never. You just get a doofus!/forums/images/icons/blush.gif I am glad you solved your problem. You know, you need a RAD CAP to go with that aluminum radiator. It had a magnesium anode in the cap that will go away prior to eating your aluminum.
Steve Leslie, 65 coupe, back on the road (watch it!) 302, toploader, A/C, disc brakes, bench seat, tri-bars, tri-Ys, now I need tri-power! 318,000 miles (8/13)
http://a4.cpimg.com/image/8E/88/5527694-efa1-022000E1-.jpg
Careful, Shaun - we may have earned ourselves one or two this summer and, if we haven't, then we'll certainly have one on the shelf this winter!!
Lance
67 Coupe 289 4v 4 Speed
69 Mach 1 351 4v 4 Speed
("other" transportation...)
http://members.home.net/stangerv8/67Mustang_files\Essesb.jpg
Well at least I'll have the steering wheel to hold onto when we "go over big" at Thunderhill!!
Damn foreign kids - NO RESPECT!!!
Lance
I won't need to hang on. Your new seats and belts should keep me nice and locked in. Well, unless you crash BIG time!
I must apoligise alaroque for LanceMach. He rambles on a bit... I think it's an age thing...
Shaun
DOOOOHHHHHHH.
We have all been there man
Paul And Michele Bradway
1970 Coupe 351W c4
1972 LTD convertible 351w fmx [soon to be 460 c6]
1 - 9 of 9 Posts
