My car was originally a fixed seat car. I am converting to a fold down. I had previously installed the fold down without the side latches... mainly because the latches didn’t line up, and I was using it as a fashionable rear seat delete - I didn’t plan on folding it up. However, children need someplace to sit, so here we are.
The problem is that both laches miss the latch holes by about an inch - they are too high. They are also probably too far towards the back of the car as well, but I can’t be sure. I originally thought that only the passenger side was off as it didn’t fit the trim panel (repops), while the driver side did... but both hit the seat at the same spot. Here are some pictures to illustrate.
Driver side with trim panel. Latch fits through the hole, but barely. It hits the rear and top of the hole. Note you can’t see the screw holes on the face
Passenger side with trim panel. You can see the holes on the face. I think that’s a trim panel problem
Driver side latch on the latch plate
Passenger side latch on the latch plate
