ive been lurking for quite a while, wanted to say hi and ask a question,
i have a 68 coupe, previous owner... well i dont know what they were thinking, car had a 2 bbl for a 390 on it, its a 289, so i took that off and put a 600 cfm holley i got for cheep, i rebuilt it, also came with a new intake manifold...
well i got it running, finally after a lot of searching and running around,
its a 4160 holley the ones with an electric choke and non adjustable floats no sight glass or plug,
i was driving around most of the day doing errands and such, had just drove to walmart, stopped for about 30-45 minutes, and she started right up, started crusing down a major street going about 50 tried to open it up and it just started to stumble as i pressed the gas, then it died at the light after running extremely rough, so i got her safe to the side of the road, and just wouldnt start, let her sit still wouldnt start, i was on the way to the gas station, (i was by no means empty) added fuel, still no start, had spark, pulled a plug wasnt wet, choke was open as it should be engine was still warm, finally choke closed and she started, died, over and over, finally got her running and home(had to get the battery charged from cranking it so much)
this is the second time its happened the last time i wasnt stuck as long, any clue? i am imagining it has something to do with the choke... i have a full 12 volts, only on while car is running, (sta terminal on alt)
