Does anyone have any pictures of their power door lock setup? In particular, the door lock installed in the door showing placement and attachment to the door lock rod for a 65-66? Thanks!
No pictures but it I did install them on my 65. It is pretty easy. All the actuators that are sold come with a clip which attaches to the door rod and the actuator rod. The hardest part is placing the actuator in a angle so it will pull and push the rod.
anyone ever try using a late model mustang power lock system? I have access to them and i was thinking about trying it. Worth a try or waist of time???
I made a "L" bracket out of heavy sheetmetal mounted to the lower window channel adjuster stud. You might also consider a keyless entry to go with the locks. I installed a keyless entry setup at the same time. It was easy to install and well worth the extra time and money to do it.
