Priming w/ oil on the engine stand?
1.7K views 9 replies 8 participants last post by  wolfeman
I am ready to prime the engine (302) before I install the distributor. Would 2 qts of oil be enough to drop in for this? It's still on the engine stand so I don't want to put in any more than necessary for this little chore. Also, anybody know what size socket to squeeze on the shaft to turn it with the drill? Thanks guys and everyone have a safe holiday this weekend...gary.
OK, Just what is the technique to prime an engine? Is this installing the starter and hooking a battery to it and then you stand back or hide behind some bricks? :peeping:. For someone whos had an engine sitting in storage like me, it might be something I'll want to do when the engine gets mounted to the engine stand. Can a compression test be done while on the stand this way? Am I crazy to think this way? Probaby so...... ::
Just a few points from my experiences. Most people don't have a priming rod. Just take about 12" worth of 1/4" extensions and tape them together with duct tape to keep them from falling apart and ending up in your oil pan. Then put your socket on the end and tape it to it also (I prefer deepwell so the tape doesn't get in the way). Make sure it will fit into the hole where the oilpump rod is and engage on the shaft by hand. I then prefer to use a cordless drill with an adapter to hook to the extensions. Here is the most important part!!! Turn your drill on REVERSE and spin away until you see oil coming out of every push rod thru the rocker arm!!! Then you are all done!! It may take a few minutes for the pump to prime before you start to see oil. You will be able to tell when the pump gets primed by when your drill starts to lug down a bit and try to spin out of your hand if you don't have a good grip on it. Hope this helps.
You must have one hell of a cordless drill! I ended up borrowing my neighbors massive, 1/2" drive, industrial style Milwaukee drill motor, as my 3/8 drive Craftsman would stall after about 5 seconds.
