Question about alternator wiring for 67 Mustang
13K views 11 replies 7 participants last post by  rickyG12345
Hoping for some help. I have noticed that one of the wires (two wires with a single loop at the end) coming from my alternator is not connected to anything but covered in electrical tape. I have a 289 V-8 with a MSD system on it. I am wondering whether this should be connected to the battery terminal side of the solenoid or I should just leave it. I have attached a picture with the wire circled. Thanks for any help you can give. Also does anyone have a photo of what the wiring should look like on the back of the alternator?
Stolen from a Mustang blog.
"You have a black wire with a red stripe that is attached to the post on the back of the alternator marked 'Grd'. This is, that's right, the ground. This is basically one wire with three ends. One end is attached to the alternator, one end is attached to the engine block on the same bolt that the negative battery cable is attached to, and the third end goes through the headlight harness and is attached to the radiator core support with one of the screws that holds the voltage regulator onto the car."
Barman10 : I can Post an illustration showing the connections to the Alternator, but first need to know a couple of things that do make a difference.
1) The harness that you pictured is for a 289 that has the in-dash Tachometer Option - is that what you have ?
2) Does your car have the Thermactor System ?
Bob
Looks like the engine Block Ground to me as was suggested above.
:eek:)
Tony K.
As note previously, the harness you pictured is not for a 289 without the in dash tachometer. The correct harness only has two wires with rubber boots on them. A harness with three rubber boots is either for a 289 with in dash tachometer, or for a 390.
Attached are illustrations showing first the 289 without tachometer, and secondly, a 289 with tachometer.
Hope this helps.
Bob
