Status
Not open for further replies.
Should I Use Gaskets with my New Carb Spacer?
18K views 14 replies 11 participants last post by  jonk67
Just received my new Edelbrock 1" carb spacer from Summit today. (Even small packages are fun to get! ::) And when I spoke with the rep on the phone last week, he said it came as a kit and assured me it would have everything I'd need.
I assumed that meant a couple gaskets would be part of that kit; but there aren't any. I do need them, right? Should I be able to pick some up at Autozone, or will I have to order these as well?
And if I do need the gaskets, what sealant would everyone recommend for this particular application?
Thanks!
You definitely need them, or you'll be asking for a nice vacuum leak. I'd call Summit and ask them to send some out to you as promised. Or just get some locally....
Save
Yeah, I was planning on 2 gaskets. I got a phenolic spacer specifically so it wouldn't conduct heat (having some hard hot starts).
What about their availability (can I use some sort of universal carb gasket) and the need for sealant?
I agree with Dicskon. Use a gasket on each side of the spacer. If it's a 4 hole spacer, use a 4 hole gasket, if it's an open spacer DON'T USE A 4 HOLE GASKET (use an open gasket) ... ask me how I know *LOL*.
You can pick up the gaskets at any auto parts store. You want gaskets for a square bore.
Save
Dan66, I can't help you, I just read your posts so I can look at your car.... ::
Save
Status
You have insufficient privileges to reply here.
