Months of building as I could, painstakingly and methodically putting everything together following guides and videos and shop manuals.
Every time I get close, I run into a part I bought that doesn't fit quite right, or I need just one more electrical connector, etc. Endless trips to O'Reilly or orders from Summit.
Example today is: I forgot to get header extenders. So I have headers installed and I have exhaust, but they can't be friends until more parts come in haha.
Got the car to the 95% point today, time to add fluids. Added the oil, no problems. A prime with a drill showed 50PSI and no leaks anywhere I could find. That Blueprint blue oil is really easy to spot.
Filled the radiator. A tiny leak a the consumable electrode, no big deal. Everything looked good so I buttoned it up for the night.
Next morning I come out to a small puddle of antifreeze under the car. Hours of looking and feeling and poking around:
Corners of the intake gaskets are weeping if I squeeze the radiator hose.
I used Right Stuff Red around the water jackets on the heads and on the gaskets and Ultra Black for the front and rear of the manifold. Looking close at a corner, there's a pinhole sized gap, no idea how that could have possibly happened.
Maybe I scraped some out by accident during the engine install or some other step.
I used recommended gaskets, FEL-PRO MS 93334
Can someone recommend a better gasket? There's so danged many options. It's a 5.0 with E7 heads. I'm using a Weiand Stealth.
Couple videos I saw recommended the printoseal version, but any time I pull up gaskets for 91-93 mustangs none of the FelPros have printoseal.
