T5 Swap: Here's my list of total parts w/cost
43K views 26 replies 20 participants last post by  kenash
#1 · (Edited)
I see a lot of T5 swap "what parts do I need?" questions, so I thought I'd put this together. i finally got the last of my parts ordered last night. My car is a '68 with the original C4 auto. I'd say I was fairly frugal about the parts I bought. Depending on how complete of a package you get when you buy a T5, you can get a bunch of the parts with it like the flywheel, block plate and clutch which will save you some cash.
'84 T5 (only bought because of the 2.95 1st and .63 5th) - $350 from a buddy
Bellhousing - Included w/transmission
Shifter base - Included w/transmission
Clutch Fork - Included w/transmission
Yoke w/driveshaft from Fox body - Included w/transmission
Transmission mount - Included w/transmission
Flywheel (used) - $40 from Californiafords.com classifieds
Block plate (used) - $15 from Californiafords.com classifieds
King Cobra clutch disc and pressure plate (new) - $120 from Californiafords.com classifieds
Longacre 36" hydraulic line (new part #LON-28050) - $30 from Summit
Throwout bearing (new) - $27 from Summit
Roller pilot bearing (new) - $14 from Summit
Clutch Alignment tool (new) - $5 from Summit
ARP Flywheel bolts (new) - $9 from Summit
Hurst shifter handle (new part #538-8022) - $80 from Summit
Hurst shifter knob (new) - $15 from eBay
Shifter boot from '69 w/Hurst shifter (new) - $15 from eBay
Shifter boot trim from '69 (new) - $12 from eBay
Clutch pedal (used) - $40 from Turlock swap meet
Clutch pedal pad (new) - $4 from Mustangs Plus
Brake pedal pad (new) - $10 from Mustangs Plus (will cut down auto pedal to work)
Clutch pedal bushings (new) - $1 from Mustangs Plus
Speedometer gear (new) - $10 from Mustangs Plus
Transmission Crossmember (new) - $80 from NE Performance Mustang
Hydraulic master, slave and bracket kit (new) - $236 from Dazecars.com
Total Cost: $1,113
Nice parts list and you got some good deals.
I think I am in for about 1200 for everything.
Others mileage may vary
Here's how I originally calculated everything out. I'd say I came in well below my initial estimate.
T5 Transmission w/o anything - (used) $300
Bellhousing (used) - $75
Shifter base (used) - $20
Clutch Fork (new) - $20
Yoke (used) - $40
Transmission mount (new) - $20
Flywheel (new) - $85
Block plate (new) - $20
King Cobra clutch kit (new) - $216
Throwout bearing (new) - Included w/clutch kit
Clutch Alignment tool (new) - Included w/clutch kit
Toploader style shifter handle (new) - $130
Toploader style shifter knob (new) - $30
Shifter boot (new) - $15
Shifter boot trim (new) - $10
Clutch pedal (new) - $140
Transmission Crossmember (new) - $140
Total Cost: $1,575
Wow. Those parts add up fast.
Yep, there's a lot of little stuff that people don't think of when doing a swap, they only think of the big things like the tranny, crossmember, clutch and yoke.
Thought I would give some input to this thread and share my costs.
This is for my early 67 Mustang originaly 6 cylinder already had a T5 out of a 87 T-Bird turbo Coupe. I converted it to a V8 at the same time upgrading the tranny to a world clsss T5. So I already had the tranny mount. Original Driveline fit the 6 cylinder and non world class T5 with an adapter plate and original 3 speed bellhousing but is 1" too long and too small (diameter/strength) so I needed a new drive shaft.
T5 World Class Transmission out of 94 Mustang GT - (used) Traded for it
T5 94 Mustang GT Bellhousing (used) - Came with Trans
Hurst Shifter base (used) - Kept the that was on the Non-world class
Clutch Fork (new) - Came with Trans
Yoke (used) - Ebay $33
Drive Shaft (new) Ebay $165
Transmission mount (used) - Already had
Flywheel (new) - $99
Block plate (used) - Came with my 302
Clutch kit (new) - Ebay $136
Roller pilot bearing (new) - Included w/clutch kit
Flywheel bolts (new) - $12 from Parts store
Thread sealer for flywheel bolts - Local parts store $6
Locktite for flywheel bolts - Local parts store $6
Hurst shifter handle (used) - Already had
Hurst shifter knob (used) - Already had
Speedometer gear (new) - Ebay $12
Transmission Crossmember - Already had
Wilwood Hydraulic master and bracket kit (new)- Ebay $35
CNC Hydraulic slave (new) - Ebay $39
Ford Racing pressure plate bolts & dowels (new)- Ebay $14
Custom Preassure plate alignment dowels (my lame flywheel had odd sized holes) made at local shop - $50
Braket to mount Hydrulic slave (made) - A couple beers
Firewall Reinforcment mounting plate for Wilwood Master - A couple beers
Starter to fit 94 Mustang GT T5 Bellhousing (used) - Ebay $38
Offset pushrod for wilwood master to pedal (dazecars.com now has them for 67) - Buying soon I think about - $40
Pushrod for slave (allthread, 2 nuts & part of heim) - $17
Total Cost: $758 and a couple beers
Hm. Honestly, my big ish is the big-buy items and actually finding some of these older cars to yank a T-5 out of. Frankly, I just wish someone had a list of vehicles that -had- the T-5 to begin with, so I could go hunting through my pull-a-part's. As for the nickel-and-diming? I can deal.
I used a T5 yoke with my new driveshaft. You can use the old one without having to cut of the non splined section on the end if you want.
Pictures of both yokes: Drive shaft
Should I pick up a 67-8 clutch pedal? or a modern one?
I thought ahead and put a manual tranny brake pedal in when I did my front discs.
Wilit: Did you have to modify the Fox Body driveshaft, or did it fit perfectly? Thanks.
I'll add...
I have a simlar list of parts and P/Ns, for when I did the swap on my early 5 bolt CVT. I used all new parts except for the clutch/brake pedal assembly, 5 bolt bell, & driveshaft (it fit). I have it on a spreadsheet, if interested.
It does add up fast!
This is a good informative thread.
If anyone has any of these parts they want to unload, pm me.
Thread Revival!
I thought I'd add my 2 cents here for anyone researching this swap. I am pretty much done with my conversion from a C4 to the T5. My parts list is listed here. A word of caution: Do NOT buy a used T5 from some random dude you find on Craigslist! Thats just my experience anyways... I picked one up for $300, got it home, popped it open and found the synchros were blown to smithereens. SWINDLER! At least the $300 included the late model bellhousing and clutch fork. Lesson learned.
T5 tranny $300, then $1295 for a new one...
Bellhousing - included
Clutch Fork - included
Transmission mount - $19
Flywheel 28oz 157tooth - $280
Clutch fork cover - $48
Clutch kit $215
Mustang Steve Cable Clutch kit w/pedal $330
T5 crossmember - $150
Shifter/handle/knob - $185
Shift Boot - $26
Speedo gear - $9.50
Backup lite pigtail - $19.50
Engine block plate - $60 (found cheaper after the fact $25)
Flywheel bolts - $15
Pressure plate bolts - $7
TOTAL: $2959 + $160 for driveshaft shortening/u-joints
PS - I have Hooker competition headers and they're smack in the way of the clutch cable... still working on that. I think I'm going to cut the offending tube and reroute it. then wrapping heavily with header wrap.:pirate:
#20 ·
$300 for a used transmission with bad synchros sounds like a fair price to me.
I paid $460 for my used T-5 with bellhousing.
-Matt
#21 · (Edited)
My swap was like this
89 t-5
Bell housing
Clutch
Flywheel
Throughout bearing
68 clutch pedal
Zbar linkage and adjustable rods because it's easier.
Shifter
Clutch fork
Block plate
Got a package for 900 bucks
Miscellaneous hardware 50 bucks
T-5 cross member 150
Driveshaft shortening and balance with new u u joints 170
Total was 1270 +- 20 bucks or so.
And it's all in my car and running well.
I've read that many are going with the hydraulic system from Dazecars, I assume it's working well since I haven't read otherwise. On the other hand I've also read and been told you might have to add a little preload to the system for it to work properly. For me not having any experience with this and from reading different places that you should avoid this (preload), I'm not sure what to think anymore. Any thoughts regarding this?
Would it be possible to just buy a MC with larger bore size and stroke?
