This question has been on my mind for some time and maybe some of you can help with a solution either through knowledge or experience.
The car in question is a 68 302 4V with an AOD and a 3:00 - 1 ratio rear end. The carb is a stock 4300. The exhaust is a Motive transverse muffler dual exhaust that is a stock replacement for the original
When the OD swap was done I did not replace the connector in the pipes from the manifold, so at present there is no "H" pipe on the car, just two individual pipes leading to a common muffler and exiting through two tail pipes. So the question is this: Will the addition of a connector between the two front pipes be of any value or is the common transverse muffler enough to take the place of the "H" in the "H" pipe? The car runs 1500 RPM at 60 MPH so the engine pretty much is loafing at highway speeds.
What are your thoughts about adding the connector - worth the effort or not? Thanks for any contribution or suggestion you may make!
